Loss of Bluetooth connection
Can I quiz your brains please…
Have enjoyed my Rs150b for a month or so gradually wading through all its functions and capabilities.
All good up until the last initiated update…The Bluetooth connection has become temperamental. Connection is refused if trying from my android phone. If I scroll to the Bluetooth setup screen I can, occasionally, secure connection.
Then the frustration is whilst playing from my phone the Rs screen defaults back to it’s home status, whereas previously it obviously used to detail the track and album status.
Coincidentally when using the touch screen a trying to select a maximise function for the track selection the unit immediately switches to a vu mode…
I have tried a substitute dongle to take that out of the equation, and also a factory reset function but no improvement.
Any thoughts
Hello, sorry for the inconvenience.
What did you play on your phone?
Also, is your RS150B connected to WIFI?
Most routers these days support 2.4G and 5G dual bands.
If you were using 2.4G WIFI, would you try 5G?
Thanks for the response…
Playing music through Qobuz on my phone. Connection is via an Ethernet cable linked directly to BT hub.
This obviously takes WiFi out of the equation.
