Lost Internet Radio Connection
Hi: My local FM station worked just fine until a couple of weeks ago, now it will not connect (WCSX in Detroit). I have a Cocktail Audio N25 and it connects just fine so I know it isn’t the feed from the radio station. Is it possible that the Rose 150B just lost the station address that I had input and that’s why it isn’t connecting? Also, does anyone have a URL for a site where you can find all internet radio addresses for local station?
I didn’t find WCSX but I did find 13 stations under Detroit (one of them may be WCSX, some don’t have call letters listed).
Go to Rose Radio, Search, Region then View All, then USA and then scroll to Detroit MI.
Thanks. this was helpful for another reason. Previously, I had to find the internet address (not just the call letters .com) and enter same to receive the station. Now I cannot access it on my Rose but I can on other streamers I have.
Maybe I can ask Rose to add the stations?
@TerryM
Please try
Rose device–>RoseRadio app–>+ button–>Enter the radio channel name in CH name and the URL.
http://playerservices.streamtheworld.com/api/livestream-redirect/WCSX_HD2AAC.aac
Hi. Thanks. Unfortunately that is the hd2 station not the main station
The WCSX main station seems to be this one:
https://playerservices.streamtheworld.com/api/livestream-redirect/WCSXFMAACIHR.aac
You can use this web site to find your favorites stations.
http://fmstream.org/index.php?c=FT
Hope this work for you.
Have a good day.
@TerryM
Streaming URLs vary from station to station, but change frequently.
As Plamf said, search for the radio channel name you want to add at FMSTREAM - The Radio Stream Directory and check the streaming URL.
