Loudness Function RS 520, ROSE firmware
I am missing a intelligent loudness function as i am used to from analog HiFi equipment.
Since the human ear is muss less sensitive for low frequencies at low volumes it helps to listen to music with a different more life like quality. Intelligent means that the higher the volume is turned up the less strong the loudness function is.
Is that possible to implement in the RISE firmware in addition to the standard equalizer function??
Loudness ? isn’t it ?
Yes yes…
https://en.wikipedia.org/wiki/Loudness
@Ben
I checked with the software team about this.
I was told that the loudness function you requested would be difficult to add later via firmware.
