Hi
Is it possible to turn on loudness normalisation in tidal,Apple Music on rose 150b?
I have problem. flac is quieter than mqa. Should be the same.
Hi
Hello @kuniu
Loudness normalization from tidal, Apple Music on RS150,
Rose device—>Settings—>Audio Settings—>Volume settings for each source.
You can use it while adjusting the volume in Volume settings for each source.
The phenomenon that Flac is quieter than mqa is a problem with the file itself.
There is no function that can equalize the volume.
