Luminosity ajustement
Hello, would there be a way to be able to have more brightness stage on my rs250. I would appreciate one or more levels between 0 and 1. thank you
@Episound
You can adjust the brightness from 0 to 15 by pressing Rose device–>Settings–>Display–>Screen brightness.
Hello thank for your response. I think it would be great to get a position or two between 0 and 1, as sweet spot.
