I cannot find the right module for the SFP to connect my Rose RS130 to my Matrix Audio SS1 pro SFP . I can get it to work with a SFP RJ 45 copper connection, but so far , all the SFP fiber optics I have do not work. Please advise if you know of a brand and model that work! Thank you so much !!
This is one of the few or possibly only one that I could make work for me:
https://a.co/d/jkfsUfP
Nokia, 10GTek, and Cisco SFP+’s were all a fail for me.
This older thread lists some other options —> Rs130 sfp brands - #16 by ZABOKS
Exactly. I have same experience. I just bought your recommendation, hopefully works for me .
Do you like your Matrix ? So far I love mine. The noise floor is ridiculously low .
Were you able to connect your Matrix SS1 to Rs130 via SFP?
I have a Microtik switch, I wish I had a Matrix. Hope that one works for you.
I just get RS130 , Matrix SS1pro , I would like to know that which SFP fiber optics can work . SFP fiber optics connection better than with a SFP RJ 45 copper connection or not. Thank you so much.
Hello sir. Here is what Matrix told me
Brand
Model
Type
Connection
Huawei
LTF1303-BH+1
SFP+ 10Gbps
Between SS-1 and other switch
Teralux
TR-CSSP5M
Direct attach cable
SFP+ 10Gbps
TP LINK
TL-SM312LS-20KM
SFP 1Gbps
Between SS-1 and MS-1
Zhongke optic-electronic AMD
ZK-GE-SM
SFP 1.25Gbps
Between SS-1 and
I’ve had good luck using genuine Cisco
