Mauvaise connexion
Bonsoir,
J’ai malheureusement une très mauvaise connexion.
C’est possible de me servir de mon partage de connexion avec mon portable Android car je suis au moins en 4g ?
Are you saying that you would like to connect the ROSE streamer to your mobile phone’s hotspot WIFI?
You can connect and use it, but be aware that it may result in high mobile charges.
Are you in a situation where you cannot connect an Ethernet cable to the Rose streamer?
(Please let me know if I misunderstood your language.)
Good morning,
yes I have an ethernet cable connected, but the connection does not allow me to read files above 48 khz 16 bits and 600 kbps and still sometimes it cuts out.
I managed to put qobuz on my phone and after having set the option on my laptop that it goes through the pink dac, that’s good, do I have the same sound quality as with the pink live qobuz ?
and yes it consumes a lot of gigabytes on my subscription, I try to download and then listen without offline but it’s not ideal!
if you can find me the most interesting solution?
Tanks à lot
