What is the largest Usb drive can be used? Will it be 22gb be too large or is it limited to less like 10Gb?
Let me explain it clearly.
The SSD and HDD to be installed in the Rose device supports up to 4TB. However, there are times when capacity beyond that is recognized. However, the capacity that is always recognized without problems is 4TB.
The HDD or USB external hard drive you want to connect to the USB port on the rear of the Rose device supports up to 10TB. However, there are times when capacity beyond that is recognized. However, the capacity that is always recognized without problems is 10TB.
