Move Radio Favourites to Rose Radio?
In advance of the change later in the year, how do we move Radio Favourites to Rose Radio?
Will there be a system update that seamlessly performs this task, or will it end up a bit of a mess, with favourite radio stations going missing?
@luxury_scruff
Click Rose device–>Radio app–>Settings–>Synchronize Rose Radio.
Then, all the favorites and the list of channels you have made in the Radio app are saved in the RoseRadio app.
When synchronise rose radio the message is in Korean, not Dutch
Thank you, I’ve set that up now.
I don’t see the items he indicated to click. In Radio app, I under Settings I only see Add Channel, no other choices. Is he referring to the mobile app or the RS-150b itself for the Settings?
I don’t see the items you indicated to click. In Radio app, under Settings I only see Add Channel, no other choices. Are you referring to the mobile app or the RS-150b itself for the Settings?
I speak English, but the message you indicate was also in Korean when I updated. However, it doesn’t matter as there is nothing for you to do or click on at that point: it is just a progress bar and closes when the installation is complete.
