MQA - Output Settings
In my Output settings for Coax Out/ Opt Out, and in the MQA Type settings, I am offered Authenticator or Decoder options.
I use a non-MQA DAC (RME ADI-2 FS) and the system setting is set out of the box as Authenticator on the RS250.
Do I keep it as Authenticator, or change it to Decoder?
If your DAC is non MQA DAC, I would recommend Decoder.
Thank you, will try that
