When I go to output settings the menu does not show the MQA type window, so I am unable to set type settings.
Did you connect your RS150B to DAC and hope to choose output of RS150B as Authenticator or Decoder?
RS150B > IN/OUT Settings > Menu on digital outputs > MQA type
Is this menu what you’re looking for? Or are you looking something else?
No external DAC connection. I Just want to get the best setting for streaming MQA files with Tidal.
If you do not connect a DAC, it seems that you are using ROSE’s DAC. In case of analog output using ROSE’s DAC, MQA is fully decoded and output.
