Multi-channel audio using HDMI pass through
Hi, I have some FLAC files which are encoded 5.1 channel and I’m using the Rose 150B with HDMI pass through turned on. I am only getting two channel stereo using the HDMI to my receiver.
Is there a setting I need to adjust to have the Rose 150B pass the multi channel audio to my receiver?
Or does multi channel HDMI pass through only work with certain file types?
Thank you!
Please check if VLC player is turned off.
RS150B > Video > Setup > User VLC Player > OFF
VLC player helps you to play videos with more codecs, but it always down-mix to two channels.
Thank you for the quick response, I have confirmed that VLC player is OFF, I can still only get two channel playback. is there anything else can I try?
Hallo
Same Problem
I have the 150b for 6 month and Never get the Multichannel running. No Flac, no DSD, nothing
I think it is a Handshake Issue HDMI, but Rose doesnt care
Greetings
I posted about this a year ago (Sept '22) under title “HDMI Out w/Passthrough”, with no response. I could not get multichannel to work so I assumed the implementation is broken. Fortunately, Roon Nucleus/Roon software solves this (except for Atmos) and the myriad other RoseHiFi software issues like improper DB sorting (artist/album), improper language/grammar translations, etc. which still have not been properly addressed.
Hello @Voyager1000 , @Schwarz and @rob63 ,
I’m apologize that I missed the word “FLAC” in the post. HIFIROSE streamer audio is for two channels only. The only multi-channel bypass to AV receiver is when you play video in ROSE streamer, not even the video from TV.
HIFIROSE streamers support two channels for audio.
@ROSELOA
Here you are wrong. There are a lot of massages from you and other Roses, that are different.
I found it. This was before i purchased the 150b
Multichannel
The answer to the link also seems like to be explaining about Video > VLC player, but I agree that may cause you confusion. I apologize for confusing you, we will correct the answer to prevent more confusion.
I have some more personal questions, would you check the message?
Hello
Dont want a refund, there is no better streamer on the market
I want Rose to improve the 150b
  • Multichannel as bitperfect on HDMI, my Sony Blu-Ray and my Raspberry can do it
  • also the Infrarot Remote Controll, as spoken manny times before
Greetings
Hello Shwarz,
I will talk about your suggestions with software team.
Once again, I apologize to confuse you.
