Hello!
I wonder if it is possible to use any ROSSE device in multiroom system, like SONOS or Cocktail Audio. If not, would ROSE is planning to develop this in near future?
Thank you for any help!
Hello!
ROSE do not support multi-room yet. In case of RS150, RS250 and RS201, if you want to use the multi-room, you can configure it by using the ROON Ready function.
In this case, you can bundle the multi-room function with other devices that support Roon ready, such as BluOS.
We plan to support multi room function between Rose devices in the future, but it seems difficult to tell the schedule as it is still in the planning level.
Thank you for your support!
Hello Rose, Have you progressed on multiroom implementation since August 2021? Kind regards
I’m sorry but not so far.
We are focusing on file managing now… I’m sorry to tell bad news.
