Hello !
I just can’t manage to transfer music from my external USB drive to the internal SSD of my Rose 250A via the network. My MacBook Pro is connected to the external USB drive via usb. i followed the steps in the instructions - as soon as i copy a folder to the internal SSD, it works for about 3 or 4 minutes. then there is a termination and an error message. (error 51). What am I doing wrong?
Why don’t you just connect the usb drive to the Rose and use it like that. Works just fine. And if you must, copy it to the internal SSD with the file manager.
If you have problems copying from your MacBook to the Rose try copying some files to the internal drive and see how that goes when you copy those to the Rose.
Also versuch Mal nicht den usb zu gebrauchen um files zu übertragen. Wenn das gut geht liegt’s an den Laptop, nicht and den Streamer. Es scheint mir ein time-out irgendwo.
I have not tried it in this way yet, as “rosehan” said that copying music data directly via USB is not possible. I will now try it via the file manager, as you wrote earlier. thank you for your advice!
