My recommendation: FW Update 1.46
@solemar
The HiFi Rose website is currently undergoing renewal.
I have sent the RD160 firmware version 1.46 file to your Gmail address.
Hi Rosehan!
Please can you comment on my post - 2 months ago?
“When I change the volume on my RA180 with the remote of the RA180, the waveform screen changes to the normal screen - that wasn’t with the older firmware. That can only be a fault of the new firmware.”
@ThIr
I’m sorry, but I do not fully understand the issue you are experiencing.
The RA180 amplifier has not received any new firmware updates in recent years.
Please record a video of the issue you are experiencing and send it to the email address below.
I will review the issue and get back to you.
After updating my RD160, the display of the RD160 always awakes when I do something with the remote of the RA180. That wasn’t the case with the former firmware of the RD160.
@ThIr
We have also confirmed that, in the latest version, operating the RA180 causes the RD160 to power on. Which RD160 version were you using before updating to the latest version?
Hi! I used the latest before the update to the new os, I don’t know the exact number. But with the latest os for the RD160 there is the same issue. Changing the volume of the RA180 wakes up the display of the RD160!
I think that issue didn’t exist in v1.24.
@ThIr
We have confirmed the issue and are currently reviewing it. A new version will be provided as soon as the fix is completed. We sincerely apologize for any inconvenience caused
@ThIr
I have fixed the issue as discussed.
You can download the updated version from the link below for your verification.
Perfect!!! Thank you!!!
Should the rest of us just go ahead and update to 1.56 or is it just a fix for this specific issue?
@Carnelian
We always recommend using the latest firmware version.
In this latest update, an issue where the RD160 responded when using the RA180/RA280 amp remote has been fixed, and the VU Meter UI has also been improved.
Thanks for that info. As we discussed previously, I think it would be good to start a new thread when there is a new firmware update. Otherwise, as far as I can tell, there is no other way to know when there is a new firmware update. The post could include high level changes/additions.
Also please note that it seems to take a LOT longer to switch to the VU or display mode once a song has started. Like minutes longer. Please fix in next update.
When I open the link there is no file there. How can I get the latest version for the RD160? Thanks!
I had to root around the goggle drive until I found a thing for “download”
Thank you, I finally found it. Thanks for the help!
Found it! Already downloaded and installed. :grinning:
