Since purchasing the RS150B, I have noticed that the automatic standby mode function either works incorrectly or doesn’t work at all. The device has a built-in timer set to automatically switch to standby mode after 1 hour.
However, after playing any content, the screen freezes on the last track, and the device may remain on for days without shutting down. I usually listen to music with the display turned off, and in this state, the RS150B also does not switch to standby mode. However, I noticed that if I return the device to the applications screen, the function works, and the device goes into standby mode.
Remote debugging is enabled.
My ROSE ID is OE8C1B.
I kindly ask you to release an update to fix this issue.
Best regards.
