Navigating RoseTube with remote
I have the Rose 150b and first version (plastic) BT remote.
I can’t access certain navigational functions of RoseTube from remote as per the below video.
Rose remote limited navigation in RoseTube demo
The buttons on either side of the Play/Pause button work correctly from the hardware unit itself, whereas from the remote they send the app back to the Home screen (which ceases the RoseTube video).
Can developers add these 2 additional navigational elements to the remote? Or is this addressed with the newer metal remote?
@taystnotes
The functions supported by the plastic remote control and the aluminum remote control are all the same. It seems that the problem will remain the same even if you replace it with the aluminum remote control.
ok but still, "Can the developers add these 2 missing navigational elements " to the interface? It wouldn’t be anything fancy for the remote itself. Clicking on either the left or right buttons if the remote should simply move the dotted selection marquee to those two missing navigational elements. Otherwise, customers have to get up and go over the Rose itself and tap on the navigational element they wish to use.
@ROSEHAN circling back a week later, please.
@taystnotes
The video you sent is no longer visible.
Please send the video or link again to the email below.
I’ll have to re-shoot a new one as I have since removed that particular one. I thought you had seen it already and at least passed it on to development team.
