Hey, I just did a firmware update on the Rose 150b to version 5.2.01 and now no analogue output. Digital works. Turns out after the firmware update the preout settings need to be turned on, which I initially overlooked.
@DHardyG
Are you using the EA version rather than the official version?
The EA version is currently in development.
Please use the official version.
RS150b–>Settings–>System info–>Use the Official version–>Update
I tried the EA version but ultimately went back to the official version. It was when I switched back that the unit performed the firmware update. As I previously noted, I forgot to turn on the pre-out settings after the update which resulted in no analogue output. I don’t use the built in software volume control, but use my preamp for that function. Thanks for the suggestion!
