If I use Tidal via Rose 150 B there is no Eric Clapton at all present. There are no mixes for you, suggested new albums etc. Please look in to it.
Best regards
I only have IPad and IPhone
It works for me on an ipad too.
Maybe log out of tidal and log in again
I would try to delete the Tidal App Cache:
Maybe it’s better to wait for an answer from the real experts
Hello @LTT
After logging out of your account on the Ros Connect app, completely close the app and try again. If that doesn’t work, try deleting the app and downloading it again.
Logging out and in again sover the problem.
