No radio working on RS250A
This morning no radio stations will connect in either rose radio or radio on my 250A. I have feed from roon working perfectly.
Also found rose tube not working either.
I have deleted data in roon radio which has not sorted the issue.
Further information - unit is connected by ethernet as is my Roon core, on the same connection. As far as I know the software is up to date and is version 5.7.07.5 and I have reinstalled rose connect premium. I do find that every couple of weeks I have to delete data within rose radio app to clear the clogged cache.
It would appear that the issue is the connection to the Rose server. I have tried to reinstall Rose radio but on the device Rose store is completely empty.
Everything works on my (520).
All working at the moment following a factory reset. Hopefully will continue to work.
