after the update I´m not able to scroll the Apps to the right or to the left in the main menu
I made a first day reset , but the problem is not solved. hmmm
What can i do ?
What can i do ?
You have to put your finger on the icons to swap, not above it or below it
That’s how it works on my RS130
Would you check if you’ve installed the APP that you need in Rose Store?
RS150B > Rose Store > Install the APP you use
Hello, thanx for your help, After the update my Rosetube and my vlc player were gone, so i hat not enough icons on the screen. i installed the missing ones and i can scroll
Thanx for help !
