can anyone help I have a rs151 just setting it up I came across a problem when I play rosetube to my tv I get no sound out of my amp its connected via xlr I can get picture but no sound any help
I’d like to confirm a few things.
- Do you not hear any sound when playing music from other music streaming apps, such as Radio, Tidal, or Qobuz, other than Rosetube?
- Please describe in detail how your RS151 is connected to other devices.
- Did you set the RS151’s input/output settings to HDMI? If so, there will be no sound.
For video output, simply connect the HDMI cable; no other settings are required in the input/output settings.
Will try that today I have streamer connected to amp using xlr and tv connected by hdmi rose tube works in the streamer without the tv on
If you tried as I said above and still can’t get any sound, please send me the details with a detailed explanation.
