Not able to connect rose connect to tab A
Good evening!
I have a question maybe someone can field: I picked up a galaxy tab A and I thought it would be cool to use it for my RS250 but when I went to download rose connect onto it I got a message saying it was incompatable with that app. So my question is has anyone else run into this problem with a galaxy tablet?
Have a great evening everyone!
@e-spaz
  1. Are you sure you downloaded the RoseConnectPremium app on Galaxy Tab A?
  2. Is your RS250 connected to Wi-Fi or Ethernet?
  3. Are your RS250 and Galaxy Tab A connected to the same IP? To use the RoseConnectPremium app, RS250 and Galaxy Tab A must be connected to the same IP.
  4. RS250–>Settings–>System info–>IP address
    galaxy tab A–>Settings–>Connections–>Wifi–>Click the gear icon to the right of the Wi-Fi connected to galaxy tab A–>view more–>IP address
    Example) Correct
    galaxy tab A IP Address: 192.168.4.33
Example) Wrong
galaxy tab A IP Address: 192.168.6.33
