Did copy a lot of music to my RS130’s internal ssd using the file manager and the Rose app does recognise all albums but I can’t play them.
What am I doing wrong?
The issue in the photo appears when the file path is changed or the file does not exist.
We can make this clear by scanning the SSD once again.
- RS130 > Settings > System Settings > Media Library > Tab your SSD > Rescan DB
I transferred 12,000+ files from an external hard drive via USB to my newly installed internal SSD and ran into same/similar issue to Bitspeed. Following Roseloa’s instructions worked for me except that my RS130 still saw my old drive even though it was disconnected, so I had 2 copies of everything but only 1 copy was playable.
I needed to go into Settings > System Settings > Media Library and select the old drive, then select Delete DB. After I did that I only had 1 copy of my music files and they all play fine now.
It was an easy process to move the files to the new drive, took about 6 hours for the 12,000+ files.
