Hi. I have an RS150 which is stuck on the Rose symbol and is not booting up. I have left it in that state for several hours with nothing but the power lead connected. I have reset the unit using the small button the rear of the unit. Forums have suggested a DC power motherboard fault. Basically I would like it repaired unless someone here can suggest a fix I can do myself. Thanks. Steve.
@BIGSTEVE
Please unplug the power cord, wait for about 1 minute (after discharging), then plug it back in and check.
If this symptom continues, there is a possibility that the DC power board is defective.
This issue typically occurs when there is a problem with the DC power board of the RS150.
It appears that the DC power board in your RS150 needs to be replaced.
Is this something common for Rose 150A ?
Are there guidelines to help avoid this or is it an issue with internal component failure?
This is not a common issue.
It may be related to an internal component problem, so if you experience this issue, please let me know.
