Hi
Before I Reported that it’s no
longer possible to search on YouTube. The field for search does no longer showNow it’s the same thing on my iPhone 13
Could you please fix this
For me the main advantage of using the rose 150 is the possibility to search and play concerts in high image and sound resolution
There is still the search function on rosetube but it’s not as performant as the YouTube
Best regards
Mikael
