I am not sure where to report software bugs. My analog output is set to fixed at 500mv. When I enable the usb output and activate software volume control (and other settings different from the analog output), the analog output then takes over these settings. Switching outputs now means resetting the parameters to what you need. I assume that’s not the intent of having distinct outputs.
Hi hififan,
Items common to input/output settings (such as Software Volume Control) are applied to all outputs at the same time.
However, in the case of preout level setting, it is only applicable to analog output, so it is better not to reset it even if you change the setting to another output.
I’ll modify it to keep the original set values.
And I will try to find similar items and improve them.
Best regards,
Kevin
