Optical or USB audio output to DAC
@ROSELOA I’m thinking about getting a high quality USB cable (Audioquest Carbon or Coffee) to connect my RS250 to my DAC. But I heard optical cables are free from RF interference. The downside is optical cables can only transmit up to 192kHz audio, but it should be sufficient for most cases. Any suggestions? Thanks!
Any suggestions for quality USB cables to use with RS250? Thanks!
Thanks for your recommendation. I’ll check it out!
