I’ve incorporated my new 150b using the optical out. I don’t have an XLR option through my preamp.
Sound quality is a bit “bright” in the high’s with my new speakers. I thought experimenting with the filter settings might be a solution in softening the sound and realized that option was only available if output was running through the RCA’s.
Should I be using the RCA’s in any case?
Thanks for any input.
