The symptom was confirmed by us and passed on to the software team. We will fix this issue and reflect it in the next update.
Have the RS201E. Very pleased with the unit. I have not updated since 4.7. Iāve decided to update to 4.17. Yesterday I tried to update but it told me that it would update to 4.12 so I canceled. Today it tells me a new update is available but when I try to update tells me that I have the latest ver. 4.7. What am I missing.
Yesterday Sunday I wanted to install the latest software and I was surprised that this didnāt work and that my version 4.7.01 was displayed as the current one. Is version 4.17.04 no longer available?
If your Rose device version is too old, the update may not be possible.
In that case, I have a way to manually update by sending the update file to your email.
If the system version information is not displayed as 4.17 even after factory resetting your Rose device (Rose deviceā>Settingsā>System settingsā>Factory reset),
please send us the model name of your Rose device to the email below and send us the update file. Please request.
Thank you for responding. I tried again last night (GMT -5) and the update went very smoothly. All is working well.
I was able to successfully install the new update yesterday evening. All applications are working correctly so far. Thank you very much for the support.
Hi I am afraid to tell you that after installed the latest firmware on my 150B and iPad, the albums files stored inside the 150b SSD cannot show the disc cover artwork on the both playlists ( right hand side of Rose Connect Premium IOS Apps) and the folder directory when open folder under Music. Please help to fix the bugs in ASAP.
Thanks!
To Rose
The latest firmware solved the problem of the missing album artwork from search folder directory which show you on the left side of screen captures. Unfortunately the new firmware created another problem of the album artwork missing after added into play lists show you on the right side of the screen capture. On matters the locations of the files stored in internal SSD of 150B or NAS.
This is a very bad experience and creating big trouble to use play list. Please answer my question and provide solution in ASAP. To be honest, itās enough for me to living with HiFiRose products. It always has problems to use.
Please check a few things.
Please find my answers as below
This is the Early Access program, you can sign up. Early Access - HiFi ROSE
I am not suggesting they canāt do better QA, because clearly they need toā¦
Figured out my issue
