see on the Korean Rose shop this remote control, have you please some informations ?
Yes, I did find this remote also at Korean webshop and it works with all streamer models.
Please make it available in Europe, looks much better than the plastic one
Itâs the remote shipped with the rs520, I havenât tried it yet, I always use the phone app
I have this remote, as I just received a new 150b, no instructions or guide, itâs cheap silver plastic, Bluetooth and wonât pair.
Itâs not even any use as a paperweight due to its flimsy nature.
In fact itâs almost as good as Roses control software, ragged and badly thought through.
Yes, i did and the remote does not show up when searching for bluetooth components, but my sony television does.
Thank you that now works, but there is no red led on the remote, itâs white and the menu key you refer to is actually referred to as the option key in the paper slip included for the RCU.
For Rose in future, please include these steps in your manual to aid new users, although the slip of paper helped with RCU keys, no pairing info was stated
Thanks for you help
