Do you have any suggestions as to how HiFi Rose could be encouraged to materially upgrade their software?
One of the problems of attaching specialized software to someone else’s operating system is that you may have to make very substantial changes to all of your specialized applications to be compatible with the current operating system version. For Eversolo this isn’t a problem because they started with the current version of Android. For HiFi Rose I suspect the answer is not that they can’t upgrade but that they could upgrade to the current Android Operating System -and then get all of the advantages that the upgrade would offer but that it would be too expensive in programming time to ensure that all of their existing applications would still function properly.Think of all of the messages we have seen on our computers…“This program no longer operates on Version XX of this software”.
I for one, would be willing to pay a subscription price to keep the programs current even though the initial purchase price is very high. It probably is an economically unsupportable model to indefinitely upgrade your user base for free without a continuously high sales volume. I sympathise with HiFi Rose but it’s a problem that must be solved otherwise the products will fall behind.
), and a $300 PC will do a much better job of ripping disks (maybe add another $30 for dbPowerAmp or similar, if you want it to be easier) than any streamer on the market.
