Hello, I am the lucky owner of a new (to me) RS150B and I would like to know if it is possible to assign specific outputs to specific sources. For example, I would like to use the balanced output for all music sources and the HDMI for all video sources, and I would like the unit to automatically switch according to the source. Is that an option?
If you use balanced output for all music sources and change the TV on/off function to on on the RS150b LCD or RoseConnect app when playing a video, the video will be played on the TV.
Thank you for taking the time to answer, but that’s not exactly what I was trying to do. Maybe I wasn’t clear enough but I actually figured it out. On my preamp, on AUX1, I connected the balanced output from the Rose. On Aux 2, I connected the AES/EBU cable as well as the HDMI cable and checked the passthrough option for the HDMI on the Rose. That way, I can hear the music via the Rose’s DAC, but process the movies through my preamp’s Dolby upmixer.
