I’m reading the RS520 manual, and has this section under 2-2-1-6 output gain:
But I can’t find this feature anywhere in the app or the rose itself.
The reason I ask you of this is because when I connect the Rose to a DAC (usb) and use the software volume control, the rose producer a loud hiss. I have reported this earlier, but then connected to a power amplifiers. I think this feature would let me reduce the output gain so that the hiss would disappear.
