Parametric Equalizer
I have tried to change the Parametric Equalizer for Custom 1 on my RS-250 without success.
Cannot find a way to save my changes on the 2nd screen. When I go back to the 1st screen and press Save, my changes are lost.
Please provide an Instruction how to set up Custom values foe the Parametric Equalizer.
Thanks in advance!
Cheers
/Torkel
In EQ display, there’s initialization button next to save button.
Any possibility maybe you touched initialization button?
Also, would you let me know which language you’re using in RS250?
Best Regards,
I use English.
It works now. On the second screen I tried to set the dB. Today I only changed the frequincies on the second sreen, and went back too the first screen and set the dB values and Saved.
Cheers
/Torkel
