Password charater limitation
Greetings to Rose Team. I am happy that finally able to stream music from my NAS to my RS201E without using third party apps (mConnect).
As noted by a couple of posters, the password on Rose app does not accept special characters even if I use my Android phone (instead of Rose touch screen).
To overcome this limitation, I had to create a new user on my NAS with a simple password. This is not good as it compromises the security of my NAS (that stores personal data in addition to music).
I would like to request Rose software team to remove this limitation on password characters on your next software upgrade.
Thank you for your feedback.
You mentioned that there are password fields where special characters are not allowed.
I believe this might refer to the password field for the NAS account.
As far as we know, quite a few special characters are already supported.
If possible, could you let us know which specific special characters you were trying to use?
If it’s inconvenient, you may also send us a private message, which would be very helpful.
