In RoseConnect app for iPhone I looked for “Settings” also “My Page” and "Find ID/PW "
none of those are terms are present in the app nor does a search reveal any of these items. Please help.
I also looked in the App for the Apple iPad. Same result.
In the iPad I can get to a point under “Edit my info” where There is a space for input to “Reset password”, however, the gold bar to click on to reset password is labeled “Withdrawal” not “Reset Password” along with the admonition that if “If you delete your account, you cannot cancel or recover it”. So, how does one simply reset a password?
I also tried to reset my password under the HiFi Rose landing page and when I try, there is a popup in Korean that I can’t read.
