I’m using the balanced outputs on the my 150B connected to a McIntosh 7200 MAC (4000 mv level on output). Phase Invert is set to OFF. Everything is working fine. I just looked at the contextual help in the MacOS Rose Connect App for the Phase Invert output setting (mouse over the ?, attached a screen shot too), and it states the following:
Off : Phase Invert off - European System
On : Phase Invert on - USA System
I am in the USA, so I would expect to have phase invert on according to the help message, but it’s turned off. Should this really be set to on in the USA?
Thanks.
