Hi Rose. I bought Philips Fidelio L3 headphones. The RS201E device sees the headphones but has no sound. I’ve tried other bluetooth headphones and the audio doesn’t work either, even though you can see them in the list
I’m sorry to tell you that Rose devices cannot be used with Bluetooth headphones connected via Bluetooth.
Rose devices can receive Bluetooth, but do not support transmission, so you cannot listen to music by connecting Bluetooth earphones/headsets.
this is terrible. I’m sorry I didn’t ask earlier because I already bought it. but nothing will change??
It seems difficult to add this feature.
Rose device’s Bluetooth module can only receive (receiver), so you need to use a separate Bluetooth transmitter (transmitter).
There is a way to transmit the optical output or analog output of the RS150 to headphones via a Bluetooth transmitter.
On Hi-Fi audio side, there is a recent Macintosh MB20 model, and if you look for it, there are many transmitter.
