WTF happened with the update?
I did not enter a passcode and now I can’t access my setting.
11111111 or 00000000 doesn’t work
I have a similar problem.
I have entered a 8 digit password but my Hifi Rose 150B says it is incorrrect.
So I have to do factory reset to come into system settings.
It would by nice if you had the possibility to view the password when you enter a new password.
I don’t understand the purpose of having a password on a streamer in the first place. Is the HiFi Rose the one and only streamer that requires a password? It wouldn’t surprise me if all RS130s in the world have 11111111, 00000000, or 12345678 as the password.
Mine was the latter.
There is no default PIN number for the Rose device.
The PIN feature was implemented to comply with EU RED certification requirements, and each user must set their own PIN individually.
Users are required to create their own 8-digit numeric PIN code.
