Any plans for editing abilities?
Use dBPoweramp to do the editing because if you wait for ROSE to do that you might be 80+
I found the best way for me is to drag the offending album from the Rose to my PC and do the editing with Media Monkey. I then drag it back and align the database. A bit clunky, I know but I’m very anal about my meta data.
No you are not. It’s OK to want data to be correct. I use my phone to do the same thing.
Honesty, I don’t expect a music server to edit your artwork. It only needs to download the right data. The database should contain the right data but often its done by amateurs. People who are not as demanding for the data to be correct like you and me.
