Hello, when I play SACD ISOs the RS150B reboots several times. Not one SACD is playing from the beginning to the end. Thanks for Help.
I assume you have the iso stored on the internal SSD.
An iso can store all sorts of data. It can be DSD or DST (compressed) stereo. But it can also be 5.1 and stereo dual layer. The Rose can’t process those. So you need to know what’s inside the iso.
There are editors that can remove the surround material and then it should work. Or rip iso to DST or DSD. That will also save a lot of space.
Investigate the source disc for answers.
I use a piece of software called Trax to strip the audio into playable files. It does not destroy or affect the original iso. Hope this helps!
