I’m trying to play from the Tidal app on PC(Win10) via USB to the RS250 and then via analog out to a power amplifier.
I have installed the Rose Audio Driver and it is set to 16 bit. There is an option of 32 bit, but then Tidal gives a message that you must use the 16 bit setting.
In Tidal I have set the RS250 as output and turned on “Exclusive mode” and “Pass thru MQA”.
If I play, what I know is, a 16 bit, 44.1 kHz, MQA 44.1 kHz Master music track everthing seems fine. However I can not find a way to see the complete signal information. Is there a way to see this when using USB input?
Now, if I play, what I know is, a 24 bit, 48 kHz MQA 96 kHz Master music track it seems like it exits the “Exclusive mode” and the sound level gets very low. Also I can see that the “VU meter” in the PC sound menu starts to light up (see picture); it does not when in “Exclusive mode”.
The same happens (exits Exclusive mode) if I play a mp4 video track.
Is it the Rose Audio Driver that is not working correctly or is there some setting I can change to make it work?
Thanks in advance
/Niklas
