Hello Roseloa,
I have a question about the listed “Playlist By TIDAL”.
All playlists stored in Tidal are listed under “My Playlist” everywhere and in all media players.
If a new playlist is created in Tidal originally, on the device or on the Rose Connected app, it is always listed in Playlist by Tidal. But not in My Playlist where they belong.
What is the function of the additional (at least for me) confusing playlist by Tidal vs. my playlist
?The main problem is:
If you delete in Playlist by Tidal, then this playlist is also originally deleted in the Tidal account. This is very annoying. That must not happen.
You don’t need the Playlist by Tidal if all playlists are in “My Playlist”.
 Can’t you just omit this “Playliest by Tidal”? The function is not known to me and is a mystery.
 If you remove “Playlist by Tidal” the menu would be tidier and clearer. Nothing is lost.
 I can’t use the function. What is this supposed to do?
Even if this function would make sense, the playlists created somewhere must always be available under “My Playlist”.
Please explain this function to me, which I consider superfluous, and for the sake of clarity please remove it from all menus.
Thanks for an answer.
