Hi, is there a way to see the difference between a Rose and a Tidal/Qobuz playlist in the ‘my playlists’ section in Rose home. The symbol for my Qobuz lists and the Rose lists in the upper left corner are the same (qobuz). It it possible to give the Rose lists a Rose symbol and/or can it be made possible to select only the Rose lists, like you can for Qobuz, Tidal end Rosetube?
Hans
Most users are using their Qobuz Playlist as it is in Rose-Qobuz due to the previous Playlist synchronization update.
To avoid confusion, could you specifically explain what you mean by the Rose list you’re referring to?
(Even if you create a Playlist from Qobuz in Rose, a Qobuz mark will appear if the Playlist consists only of Qobuz songs.)
(And I guess you know how to sort the playlists)
Hi Roseloa,
What I meant was that when you sync a Qobuz or Tidal playlist to a Rose playlist, that both show up in the ‘My Playlists’ section in the Rose Home app. And in my case; all three show up. One with an little Tidal icon, and two with a Qobuz icon in the top left. I can’t see which one is the synced Rose version and which one is the original Qobuz version. Even in the Qobuz app (in the Rose app) I see two versions of the same playlist. Also my friend (a Rose friend in the app) is seeing three versions of all my playlists. Or am I doing something wrong when I sync all of them?
