I have Qobuz subscription with multiple playlists. I have RS250 and stream Qobuz. How can I see or import my Quobuz playlists to Rose? I can create new playlists in Rose and see in my Qobuz external app, but can’t see any of my preexisting Qobuz playlists on the RS250.
Have you linked your Qobuz account on the 250 ?
Are you using the Rose app ?
I have my Qobuz account linked and use the Rose app and do not have any issues viewing my playlists or favourites.
I believe my Qobuz account is linked… I don’t think I could be listening to Qobuz if it wasn’t. If I use the Qobuz app (away from home for example) I can see any playlist that I created when using Rose app, but on the Rose app I can’t see the playlists from my Qobuz app.
In the Rose app, go to…My Account…Playlists…
Your Qobuz, Tidal, or All Playlists should be there.
Click on your Qobuz playlist; it should open, and a pop-up menu will appear, asking you whether you want to sync from Qobuz to Rose or from Rose to Qobuz.
Then sync, and everything should be fine.
That’s how I’ve always done it on the RS 520.
But I don’t know if it’s still implemented that way in the software.
I finally found a synchronize button buried in a menu. Wasn’t as intuitive as i’d hoped but finally succeeded. Thanks to all who responded.
