So today I actually created around 200 playlists from my music stored on internal ssd using rose app on iPad. Working great via app. But in the unit itself around only 40 playlists are visible.
Plus I wanna know is there a way to sort the folder contents from device itself just like we have the option in the mobile app?
We apologize for any inconvenience caused during use. Currently, we are not able to confirm the symptoms. I have a few questions for you.
- What is the model name of your iPad?
- Please send your rose account account and password via private message.
Thank you for your help.
We entered your account on the iPad, and all 187 playlists are displayed just fine.
Can you show me a picture showing only 40 playlists?
Find attached… playlists in the unit starts from “R” to “Z” or if I’ve modified any playlist that playlist shows in this case the first playlist “Nazia & Zohaib” the name of the playlist was modified.
Currently, only 50 of your account’s playlists have confirmed symptoms displayed on the unit. It will be updated after correction.
At this time, we have not received an exact schedule for the next update.
However, the update will be released in early or mid-February.
We have not been notified of the update schedule yet.
We’ll let you know when the schedule is set.
I really apologize for the delay in the update schedule. I was informed that the update will be held next Thursday.The issue has already been fixed and will be updated.
he didn’t specify which thursday of which month of which year
Once again, I’m sorry to tell you that the update will be implemented within this week.
The update works great thanks a lot. Just one thing I’ve noticed. There should be a way to spell the playlists by alphabetical order on the rose itself. It shows playlist by the last edited or last added at the top.
Hello @Umar
You can sort the playlists you create alphabetically.
Rose device–>RoseHome–>House button on the top left–>My Playlist–>If you click the part marked in red in the picture below, you can select how to sort the Playlist.
RoseConnect app–>Home–>My Playlist–>View all–>If you click the part marked in red in the picture below, you can select how to sort the Playlist.
no software update yet
