The RS150 is very good, but I want a stream only, no DAC (I’ve got my own). Here are the features I want you to build in a perfect “streamer only” RS150:
- no DAC
- large 14" touch screen panel
- while streaming hi-res music, ability to play matching music video (video from youtube, but music from hi-res source)
- display lyrics along with video, maybe in 30/70% split window
- integration with Amazon HD music
- room correction (microphone input, automatic digital output adjusted for flat response)
- 3 digital 2-channel outputs (for 3 different DACs going to 3 different frequency speaker drivers)
- digitally filter the frequency range going to each of the 3 digital outputs
- digitally adjust volume level going to each of the 3 digital outputs
- digitally adjust a time delay going to each of the 3 digital outputs
If you build this, I will happily buy at least one, maybe several.
