Pontus II HDMI Input
Rosehan, I bought a DVI-D to HDMI A cable and connected it to my Pontus II and selected played mode A, but I get clicking sounds. Does the fixed volume need to be lowered? Here is Pontus II HDMI input.
Thanks Billy
I used Mode A on the 150B and put the Pontus ll in I2S input and pressing the Mute button once to enter the I2S configuration mode and pressing the phase button until the clicking stopped.
Thanks Billy
Hi, i just posted a message about DVI to HDMI
I have a Denafrips Terminator II
I know how to change the config on the T2, it works the same as pontus 2
But how do you switch between the rose mode a and mode b
I use a normal dvi to hdmi converter cable
Eric
@Bitspeed
