Buenas tardes,
Hay posibilidad de incorporar un ecualizador proximamente?
Hello @Alicante1963
Currently, Hi-Fi Rose supports “Equalizer” function only for RS201.
I will check and let you know, if there is a possibility of adding an “Equalizer” function to other devices.
Gracias, es importante contar con la opcion de un ecualizador de calidad, y igual podria ser factible con el hardware que ya tiene el rs 250 o 150b? Solo seria curstion de software?
Saludos
Hello @Alicante1963
There are a lot of people who are against EQ on models that do not have amplifier.
However, if a positive request arises, we will review it.
